[Em...] Posted August 5, 2022 Share Posted August 5, 2022 Hi, I am messing around with the info dialog widget, as it enables the script to continue in the background, which sounds interesting. However, I am experiencing that as soon as I have run: gom.script.sys.open_user_defined_dialog(dialog=widget) - the script will close the dialog-widget afterwards, when it jumps to the next line of code, without the function gom.script.sys.close_user_defined_dialog() being called. Are you supposed to set a state to the dialog so that it remains open? Am I forgetting something? Full code below: import gom class Dialog: def __init__(self): self.START_DIALOG=gom.script.sys.create_user_defined_dialog (content=content) self.START_DIALOG.handler = self.dialog_event_handler(widget=self.START_DIALOG) self.open(self.START_DIALOG) def dialog_event_handler(self, widget): pass def open(self, widget): gom.script.sys.open_user_defined_dialog(dialog=widget) def close(self, widget): gom.script.sys.close_user_defined_dialog (dialog=widget) if __name__ == '__main__': run = Dialog() Thanks, Emil. Link to comment https://qualityforum.zeiss.com/topic/1239-info-dialog-closes-unexpectedly/ Share on other sites More sharing options...
[87...] Posted August 10, 2022 Share Posted August 10, 2022 Do you actually have any code that is executing? When I tried this, I inserted a "delay_script" after the "run = Dialog()" line, and it remained open for the duration of the delay Although I think this might be an overcomplicated way of doing this info dialog, it can be done easier (I inserted a delay where your code will go). The important part is to have a "gom.script.sys.open_user_defined_dialog" before your code to be executed, and a "gom.script.sys.close_user_defined_dialog" at the end of your code # -*- coding: utf-8 -*- import gom DIALOG=gom.script.sys.create_user_defined_dialog (content='<dialog>' \ ' <title>Dialog Title</title>' \ ' <style></style>' \ ' <control id="OkCancel"/>' \ ' <position></position>' \ ' <embedding></embedding>' \ ' <sizemode></sizemode>' \ ' <size height="142" width="198"/>' \ ' <content rows="1" columns="1">' \ ' <widget row="0" rowspan="1" type="label" column="0" columnspan="1">' \ ' <name>label</name>' \ ' <tooltip></tooltip>' \ ' <text>hello world!</text>' \ ' <word_wrap>false</word_wrap>' \ ' </widget>' \ ' </content>' \ '</dialog>') # #dialog opens and is displayed to the user # gom.script.sys.open_user_defined_dialog (dialog=DIALOG) # # your code starts here # gom.script.sys.delay_script (time=2) # # your code ends here # # #dialog closes # gom.script.sys.close_user_defined_dialog (dialog=DIALOG) Link to comment https://qualityforum.zeiss.com/topic/1239-info-dialog-closes-unexpectedly/#findComment-4059 Share on other sites More sharing options...
