Confuse about various points method
The difference is all about how the difference between the ball center and compensated point is calculated.
The below is from the help file, under "basics of the point feature"
  • 4 weeks later...
Below is something regarding the big 3, as far as I'm concerned. This may not be totally accurate but I think it's close.
Touch points, which is the default evaluation when creating single point features on a model or part. Touch points will always snap to the closest primary axis, which could be from the base alignment, or a secondary alignment when using the Pre-Assignment function. Touch points are usually good to establish a depth or location of a plane that is normal to the X, Y or Z direction of the alignment used. The I, J or K value will typically be 1 or -1 which indicates the direction of the point vector. This value is the cosine value of the point vector cos 0° = 1 and cos 90° = 0 So, a point on the left side of a part, will have a -1.000 in the I field and a 0.000 in the J and K field.
Space points, which are the easiest to create from a model. Wherever you click on the model, it will read the surface vector and apply it to the I, J or K value. It is typically used to report how high or low the surface is from it's nominal. Often used as a quick profile check where the .010 profile tolerance is cut in half and converted into a ±.005 tolerance.
Plane points are similar to Space points in that they use the surface vector. The easiest way to create one it to create a Space point from the model, then change the evaluation to plane point. I've attached a Point presentation by Ryan Stauffer where he says "Assuming plane measurement always" under the description of a Plane Point. Not sure exactly what he means.
Point.ppt
Thanks everyone for the helpful info. Definitely easy to get confused.
Tom,
I think the point.ppt means plane point always assumes it is on a (nominally flat) 'plane' feature.
  • 1 month later...
