ERROR_SHARING_VIOLATION
Hello everyone
I have a problem.
I want to measure a 3D curve. With PCM commands I have programmed that the "old" curve is deleted, the new curve is actually calculated and read into the 3D curve as a ....txt file.
Everything works with the 1st program run. The 2nd program run does not work. The following error window appears . If I quit CALYPSO and re-strate, everything is okay until the second run ... the same error ... 870_ba68bd36573d0224115372de553fbaea.png
I have already reported that bug (Bug235015)
It happens on 7.2 and 7.0.12
Will be solved on Patch 7.0.12.02 and Patch 7.2.0003
