ISO5458:2018 symbol "SIM"
Dear Team,
Now we have a question about the symbol"SIM". How do we build the alignment? could you help me? Thanks in advance. 4358_ea2191f002cee77964e5c29a513118c1.png
I would measure the side planes of the slots, make center planes, construct centroids of the planes, and use those and the bores in a bore-pattern best-fit.
No, there are no constraints except for datum A, and since there are no constraints except for datum A, you can choose an arbitrary solution. The call-outs are in conformance if you find at least one solution where they’re in tolerance. One way to find such an arbitrary solution is the best-fit as I described it. The envelope condition (E) has no influence on the position or the symmetry (ISO -> Independency principle).
Hey, you’re right, this is comedy.
