[Ji...] Posted July 23, 2021 Share Posted July 23, 2021 Dear Team, Now we have a question about the symbol"SIM". How do we build the alignment? could you help me? Thanks in advance. Link to comment https://qualityforum.zeiss.com/topic/12434-iso54582018-symbol-quotsimquot/ Share on other sites More sharing options...
[Ma...] Posted July 23, 2021 Share Posted July 23, 2021 Hi, there is info about it. SIM is for Simultaneous requirement - aka pattern. Somewhere in piece are those elements ( plane, cylinder ) interupted. Like pattern for CZ. But i think there should be SIM1 for symetry and SIM2 for position. https://www.mmscience.eu/journal/issues ... s/download Link to comment https://qualityforum.zeiss.com/topic/12434-iso54582018-symbol-quotsimquot/#findComment-62230 Share on other sites More sharing options...
[To...] Posted July 23, 2021 Share Posted July 23, 2021 Is it possible using Best Fit Bore Pattern of all required features? Link to comment https://qualityforum.zeiss.com/topic/12434-iso54582018-symbol-quotsimquot/#findComment-62232 Share on other sites More sharing options...
[Da...] Posted July 23, 2021 Share Posted July 23, 2021 The same number shows that the same simultaneous requirement must be applied. Link to comment https://qualityforum.zeiss.com/topic/12434-iso54582018-symbol-quotsimquot/#findComment-62234 Share on other sites More sharing options...
[Ji...] Posted July 23, 2021 Author Share Posted July 23, 2021 how do we build alignment, if it is marked on some different line form? Link to comment https://qualityforum.zeiss.com/topic/12434-iso54582018-symbol-quotsimquot/#findComment-62236 Share on other sites More sharing options...
[Da...] Posted July 23, 2021 Share Posted July 23, 2021 I would measure the side planes of the slots, make center planes, construct centroids of the planes, and use those and the bores in a bore-pattern best-fit. Link to comment https://qualityforum.zeiss.com/topic/12434-iso54582018-symbol-quotsimquot/#findComment-62238 Share on other sites More sharing options...
[An...] Posted July 23, 2021 Share Posted July 23, 2021 ___ Link to comment https://qualityforum.zeiss.com/topic/12434-iso54582018-symbol-quotsimquot/#findComment-62240 Share on other sites More sharing options...
[Da...] Posted July 23, 2021 Share Posted July 23, 2021 Please sign in to view this quote. No, it doesn’t change a thing about the position. Link to comment https://qualityforum.zeiss.com/topic/12434-iso54582018-symbol-quotsimquot/#findComment-62242 Share on other sites More sharing options...
[An...] Posted July 23, 2021 Share Posted July 23, 2021 ___ Link to comment https://qualityforum.zeiss.com/topic/12434-iso54582018-symbol-quotsimquot/#findComment-62244 Share on other sites More sharing options...
[Da...] Posted July 23, 2021 Share Posted July 23, 2021 Please sign in to view this quote. No, there are no constraints except for datum A, and since there are no constraints except for datum A, you can choose an arbitrary solution. The call-outs are in conformance if you find at least one solution where they’re in tolerance. One way to find such an arbitrary solution is the best-fit as I described it. The envelope condition (E) has no influence on the position or the symmetry (ISO -> Independency principle). Hey, you’re right, this is comedy. Link to comment https://qualityforum.zeiss.com/topic/12434-iso54582018-symbol-quotsimquot/#findComment-62246 Share on other sites More sharing options...
[An...] Posted July 24, 2021 Share Posted July 24, 2021 ___ Link to comment https://qualityforum.zeiss.com/topic/12434-iso54582018-symbol-quotsimquot/#findComment-62248 Share on other sites More sharing options...
