Pause button error on Joystick
I was running a program on an Accura II and it hit the pause/stop button for the stop light, which I've done countless times and when I hit the green button to continue running the program it measured about 5 features and all of the sudden stopped in a hole and now is stuck and nothing is working to get it back running. I've turned off the machine about 4 times now and it will not home, always coming back to that Pause symbol on the joystick itself.
I've put in a ticket for service but have any of you ever experienced this?
So, you've restarted both the CMM controller and the Calypso computer? If not, do.
Make sure the cord to the joystick box is secured and that no buttons are sticking.
Other than that, I have no idea.
Good luck.
Thanks buddy, I figured it out.
I'm proving out programs for an automation setup for an Accura and our maintenance guys killed all power to the robotic cell so it had no connection and that's what did it. Problem solved, everybody learnt 🤣
