Modeling TP20 Probes in Stylus System Creator (SSC)
Hello,
I was wondering if it was possible to model Renishaw TP20 probes in the Stylus System Creator. I see TP200 styli, are those the same or something different? If you cannot directly model the TP20's, does anyone know of an alternate that is similar?
Thank you!
If I remember right from my dmis days the 200 is longer and with the adapter its even longer. The 20 is shorter.
Again going off memory from a long time ago
  • 4 weeks later...
I was also looking for this and found it recently in the SSC, when you make a new systum choose "RDS" the option for the RDS-TP will show then change the manufacturer to Renishaw and you will find the TP 20 with which ever module you have.
