disc probe qualification with XXT
Trying to qualify a disc probe using an XXT head but I do not have disc option under the geometry dropdown in the probing system qualification window--sphere is my only choice. Am I missing something? Can XXT qualify a disc probe?
  • 4 months later...
Would it be possible to get both sides of a narrow ID groove with this method? Would you have to create 2 stylii? One with Z going to bottom of disc and one going to top.
Z motion with a disc probe will drive you to drinking trying to figure it out. You could create multiple styli of the same disc and offset the Z property to get it done.
  • 2 years later...
Hiii Tom,
Thanks for ur excellent information so far.But I got struggling with geometry data(X,Y,Radius) edit process and if I have more length of shaft in disc probe compare with existing probe length how can i correct it z direction. How can edit it with matching of ring gauges dia report deviation. Can u explain in deeply?
Thanks in Advance for your prompt reply.
