[Pa...] Posted July 6, 2018 Share Posted July 6, 2018 Trying to qualify a disc probe using an XXT head but I do not have disc option under the geometry dropdown in the probing system qualification window--sphere is my only choice. Am I missing something? Can XXT qualify a disc probe? Link to comment https://qualityforum.zeiss.com/topic/12472-disc-probe-qualification-with-xxt/ Share on other sites More sharing options...
[Vo...] Posted July 8, 2018 Share Posted July 8, 2018 Hi Paul, it dosn't work's! Volker Link to comment https://qualityforum.zeiss.com/topic/12472-disc-probe-qualification-with-xxt/#findComment-62478 Share on other sites More sharing options...
[Me...] Posted July 9, 2018 Share Posted July 9, 2018 So what to do in leu of this? Link to comment https://qualityforum.zeiss.com/topic/12472-disc-probe-qualification-with-xxt/#findComment-62480 Share on other sites More sharing options...
[Me...] Posted July 9, 2018 Share Posted July 9, 2018 I think Tom Oak posted how to qualify disc probe in old Forum. Link to comment https://qualityforum.zeiss.com/topic/12472-disc-probe-qualification-with-xxt/#findComment-62482 Share on other sites More sharing options...
[Me...] Posted July 9, 2018 Share Posted July 9, 2018 Thanks I found it. I have attached it (thanks Tom).Create_Disc_Probe_for_VAST_XXT_140315 (1).pdf Link to comment https://qualityforum.zeiss.com/topic/12472-disc-probe-qualification-with-xxt/#findComment-62484 Share on other sites More sharing options...
[Pa...] Posted July 9, 2018 Author Share Posted July 9, 2018 thank you all Link to comment https://qualityforum.zeiss.com/topic/12472-disc-probe-qualification-with-xxt/#findComment-62486 Share on other sites More sharing options...
[Me...] Posted November 12, 2018 Share Posted November 12, 2018 Would it be possible to get both sides of a narrow ID groove with this method? Would you have to create 2 stylii? One with Z going to bottom of disc and one going to top. Link to comment https://qualityforum.zeiss.com/topic/12472-disc-probe-qualification-with-xxt/#findComment-62488 Share on other sites More sharing options...
[To...] Posted November 12, 2018 Share Posted November 12, 2018 Z motion with a disc probe will drive you to drinking trying to figure it out. You could create multiple styli of the same disc and offset the Z property to get it done. Link to comment https://qualityforum.zeiss.com/topic/12472-disc-probe-qualification-with-xxt/#findComment-62490 Share on other sites More sharing options...
[ST...] Posted July 19, 2021 Share Posted July 19, 2021 Please sign in to view this quote. Hiii Tom, Thanks for ur excellent information so far.But I got struggling with geometry data(X,Y,Radius) edit process and if I have more length of shaft in disc probe compare with existing probe length how can i correct it z direction. How can edit it with matching of ring gauges dia report deviation. Can u explain in deeply? Thanks in Advance for your prompt reply. Link to comment https://qualityforum.zeiss.com/topic/12472-disc-probe-qualification-with-xxt/#findComment-62492 Share on other sites More sharing options...
[Ri...] Posted July 20, 2021 Share Posted July 20, 2021 Please sign in to view this quote. This is why I will always build a T or Star probe before using a disc. Link to comment https://qualityforum.zeiss.com/topic/12472-disc-probe-qualification-with-xxt/#findComment-62494 Share on other sites More sharing options...
