Formula for nominal position.
Hello all,
I'm sure this is covered somewhere on this forum but I can't seem to find what I am looking for. I have a simple circle on cylinder with its nominal "X" location based on the location of an associated space point in the same axis. These features repeat multiple times along the "X" axis and I need to measure each one individually. I initially established a pattern but I need the circle on cone to be the same distance from the associated space point for each feature. What would be the formula to put in the "X" axis nominal box? Thanks in advance.
If I'm understanding correctly, you can use formula in the cone feature
X coordinate; getNominal("Point1").x for each cone/point. Plus a distance
if needed getNominal("Point1").x + 0.005
