Green/Red measured surface arrows
I am trying to measure a bit of a blind hole in the center of a part with 3 stepped inner diameters. The farthest and smallest one down I can't really see if I'm actually getting my target. I was hoping that the green arrows of the measure surface would show me if I'm close or not but they don't seem to appear anymore was a setting deleted when I updated to Calypso 2021?
I'm on a Contura with a Vast XXT RDS.
I usually find sections that I can't see with the stoplight window. At the bottom of the window is a pull down that says CMM system , tap on that and set to base alignment. Now the readouts are displaying the coordinates to the base alignment so you can drive to print dimensions and touch off that way.
Opening a feature and right click to show the actual points is what I needed thanks! Whew that scan needed some adjustment too good thing thanks for the help!
