[Ky...] Posted July 15, 2021 Share Posted July 15, 2021 I am trying to measure a bit of a blind hole in the center of a part with 3 stepped inner diameters. The farthest and smallest one down I can't really see if I'm actually getting my target. I was hoping that the green arrows of the measure surface would show me if I'm close or not but they don't seem to appear anymore was a setting deleted when I updated to Calypso 2021? I'm on a Contura with a Vast XXT RDS. Link to comment Share on other sites More sharing options...
[Da...] Posted July 15, 2021 Share Posted July 15, 2021 I usually find sections that I can't see with the stoplight window. At the bottom of the window is a pull down that says CMM system , tap on that and set to base alignment. Now the readouts are displaying the coordinates to the base alignment so you can drive to print dimensions and touch off that way. Link to comment Share on other sites More sharing options...
[Ro...] Posted July 15, 2021 Share Posted July 15, 2021 Open a feature. Right click in the CAD window / Show actual points (Green) / Show masked points (Red) Link to comment Share on other sites More sharing options...
[Ky...] Posted July 15, 2021 Author Share Posted July 15, 2021 Opening a feature and right click to show the actual points is what I needed thanks! Whew that scan needed some adjustment too good thing thanks for the help! Link to comment Share on other sites More sharing options...
