Send to printer
I done this and it worked...
In multiple report window check the printer icon under Output Media..
Then I check the "Send results to printer" in the start up screen. Its right above the Clear results radio button
  • 3 weeks later...
I have seen the select printer in the start up window cause issues with the PiWeb printout because you are asking it to double print, have seen it lock up PC's
