Save a program for use with an older version of Calypso
Im dealing with a sister plant, They bought a new PC (maybe directly from Zeiss) which has a new version of calypso running on it.
Over the phone, I walked them thru getting everything setup and running, loading a backup onto the new computer so all the probes and settings are taken care of, and yesterday, mid day, they were up and running.
***Both machines are running in autorun, and running the same programs from the network***
The problem is that overnight someone ran the probe cal program on the new machine, in regular Calypso (not autorun), and when it was done they hit save before closing.
So now the old machine cant open the probe cal program.
I think the versions involved are 6.4 (2017) and 7.2, so its not that the old computer is running crazy old software, im surprised there is an issue at all.
However, i know there is a way to back save revs, but i cant remember how to do it.
Roberto,
attention
first get a copy. Then in the inspection folder open/edit the point version write 6.4, then delete the insept data.
There any parameter delete too, in Basesystem the Button "Set base alignment zero" is falied, if tehte sve parameter they are delete too...
I hope that works 🤬
So in the end, they were able to grab a copy of the probe cal program from IT, and their periotic network "backup tapes".
But thank you Marti.
I'm gonna go ahead and tag this entry with words like "backsave" and downrev" because this has happened before and will def happen again to me or someone, and all the search words I tried earlier gave me 30+ pages of results.
Crisis averted.
