White window of death
I keep getting a warning window that is blank. It locks up calypso and won't let me do anything. I have to close out calypso and then restart my program from where it was. How do I get this to stop?
I recall this happening in older versions of calypso. It normally was a dependency issue with a feature using an alignment that was dependent of another alignment or hidden PCM errors.
Try selecting the ctrl key and Y at the same time to bring up a window or monitor menu that will allow you to create an error report and then read it to see if points anything out that you can understand.
Have a great weekend!
I moved the program to another CMM and the problem went away. Not sure what is going on. This same CMM broke my probe
during a sideways check by trying to push the part and then tells me the point is not in the search path.
