[Da...] Posted July 9, 2021 Share Posted July 9, 2021 Looking for some help with measuring a cam shaft. There are 4 Exhaust CAM Lobes & 4 Intake CAM Lobes. I am familiar with curve, so I figure I can scan the each lobe as a 2D curve with 360 nominal data points and be done. Unfortunately this is not the case. What I need to report are the lift table angles for the opening and closing. Program is attached along with dimensions highlighted that I need to check.Lift Table Angles 46 thru 76.pngLift Table Angles 19 thru 45.pngLift Table Angles 0 thru 18.pngcamshaft question.zip Link to comment https://qualityforum.zeiss.com/topic/12542-help-with-measuring-a-cam-shaft/ Share on other sites More sharing options...
[Ow...] Posted July 9, 2021 Share Posted July 9, 2021 Not sure this ever got resolved but, the link below goes over what you're trying to do. viewtopic.php?f=13&t=481&hilit=Cam&start=10 Link to comment https://qualityforum.zeiss.com/topic/12542-help-with-measuring-a-cam-shaft/#findComment-62798 Share on other sites More sharing options...
