[Th...] Posted June 25, 2021 Share Posted June 25, 2021 If I viewed any model from straight top or bottom view, the surface turns shiny and I can't view the elements' label. Anything in setting to turn off reflection on surface?Untitled.pngUntitled2png.png Link to comment https://qualityforum.zeiss.com/topic/12584-cad-model-view-reflection/ Share on other sites More sharing options...
[Ja...] Posted June 25, 2021 Share Posted June 25, 2021 Try changing color of the part itself. That should work. Link to comment https://qualityforum.zeiss.com/topic/12584-cad-model-view-reflection/#findComment-63008 Share on other sites More sharing options...
[Ja...] Posted June 29, 2021 Share Posted June 29, 2021 You can change the color of the text to black under CAD-settings-colors. Link to comment https://qualityforum.zeiss.com/topic/12584-cad-model-view-reflection/#findComment-63010 Share on other sites More sharing options...
[Ma...] Posted June 29, 2021 Share Posted June 29, 2021 I would like to remove reflection too. Like in SolidWorks. No color change removes it - only certain colors helps a bit. Link to comment https://qualityforum.zeiss.com/topic/12584-cad-model-view-reflection/#findComment-63012 Share on other sites More sharing options...
[To...] Posted July 1, 2021 Share Posted July 1, 2021 Please sign in to view this quote. Technically, it is not a reflective condition. It is the actual color assigned to the model. So, white text on white model is the issue. As in previous posts, changing the model or text color should fix your issue. Link to comment https://qualityforum.zeiss.com/topic/12584-cad-model-view-reflection/#findComment-63014 Share on other sites More sharing options...
[Te...] Posted July 2, 2021 Share Posted July 2, 2021 To minimize this I also turn my boundary black, the colors I use most of the time is Orange for the part and black for the boundary, at least this way I can see the features. You could also try changing the text color to red or black instead of white Link to comment https://qualityforum.zeiss.com/topic/12584-cad-model-view-reflection/#findComment-63016 Share on other sites More sharing options...
