Planner/Simulation on DuraMax
I always seem to struggle with setting up a DuraMax in Planner. Since the XXT Sensor is mounted in the machine with the 1 dot facing in the -X direction, I understand I can rotate the Main Axis -90 in Stylus System Creator so that it appears in the same orientation but after I import a star stylus system, the X and Y values are reversed. If I use +90, then the X and Y values are correct but I'd like to understand what the steps are to make everything look like it's supposed to.
All I do is create the stylus I want and then update the nominals for the correct vector. With a star probe it is very easy because you just have to modify the X and Y values and rename the styli. So for a T or a Star using different size tips, create it and then load it, I usually take a snip of the nominals and the adjust accordingly.
