Cone Calculation
I just noticed that:
You can adjust the evaluation method in the Cone Addition Calculation of the Cone feature to all of the standard: LSQ, Outer Tangential, etc..
BUT
The diameter characteristic that is reported shows LSQ evaluation method, as a default and cannot be changed... even though the actual result is calculated to the method that is defined in the Cone Addition Calculation.
Wondering if this is an oversight, and if LSQ should be the default for the cone calculation (and one should not be able to modify the Cone Addition Calculation eval method....OR... if the diameter charactedistic should actually be showing the Cone Addition Calculation defined method.
