[Ja...] Posted June 23, 2021 Share Posted June 23, 2021 We have the following controller Is there a way to restrict translation along a particular axis? I'm thinking that the X, Y, and Z keys must be able to do this somehow. Link to comment Share on other sites More sharing options...
[Ow...] Posted June 23, 2021 Share Posted June 23, 2021 Attached is the manual for that box. I always use the menu in the stop-light, select more and then lock joystick and a window opens up to choose which axisNew Zeiss Control-joystick box_26SE_.pdf Link to comment Share on other sites More sharing options...
[Mi...] Posted June 23, 2021 Share Posted June 23, 2021 The ol 26 box. I think its shift and then the axis button(s) to the left of the "Slow Mode".. Or just the axis button(s) alone. I cant remember lol. I have the 26e and been using it for a few years now. Link to comment Share on other sites More sharing options...
[Ow...] Posted June 23, 2021 Share Posted June 23, 2021 Oops, the attached is for the new 26SE box, not the older one without the LCD screen. Thought I had a manual for it but, can't find it Link to comment Share on other sites More sharing options...
[Mi...] Posted June 23, 2021 Share Posted June 23, 2021 Might be shift/return then the axis you want to lock. The new 26e uses shift/return for certain functions Just tossing out suggestions... Link to comment Share on other sites More sharing options...
[Ja...] Posted June 23, 2021 Author Share Posted June 23, 2021 Weird, I've tried pressing the buttons and pressing the Shift/Return buttons at the same time and it doesn't seem to work. I will check out my options in the stoplight, but ideally it'd be done at the controller. Link to comment Share on other sites More sharing options...
[No...] Posted June 24, 2021 Share Posted June 24, 2021 Typically, you have to press the LOWER half of the return button. Link to comment Share on other sites More sharing options...
[Ja...] Posted June 24, 2021 Author Share Posted June 24, 2021 Unfortunately that didn't work either. Link to comment Share on other sites More sharing options...
[Mi...] Posted June 24, 2021 Share Posted June 24, 2021 Found this in an old 5.6 manual NO idea if it helps ya out Link to comment Share on other sites More sharing options...
[Ja...] Posted June 24, 2021 Author Share Posted June 24, 2021 Mike, Thanks for pointing me to that. It does in fact work for me. The only problem is that the CZ Control Panel Extension window needs to remain open for the assigned function keys to do anything. Once you close the window, the function keys no longer do anything. At least I know it is possible one way or another. I will do some digging to see if I can find a better way. I also work with a Sheffield CMM and there are buttons on the joystick that do this. It is much simpler. Link to comment Share on other sites More sharing options...
[Mi...] Posted June 24, 2021 Share Posted June 24, 2021 Good. I started out on a Sheffield 1808 back in 98. Retro fitted it with QC-5000. Even had a foot switch. Take a point hit the foot switch haha The good ol days Link to comment Share on other sites More sharing options...
