Fast probe mode on vast xxt
Touch trigger probes are different by design. They use switches that open upon contact or piezo elements that listen for probe contact. XXT sensors only work based on a certain amount of deflection, i.e. Standard 150um, Sensitive 100um and Robust 200um.
As Norbert mentioned , the new "fast" option will shorten the time it takes to take a point but is only intended for measurements where less accuracy is acceptable.
