[Da...] Posted June 4, 2020 Share Posted June 4, 2020 I finally found a Laptop that will keep up with my desktop computer If you use Dell Computers All 12 of the DuraMax computer are Dell running Intel(R) Xeon(R) CPU E3-1270 V5 @3.60 GHZ Ram is 64 GB Nvidia Quadro M2000 Card I tried the Zeiss sugested HP but didn't love it. My new Laptops are Dell Percision 7540 Running Intel (R) Xeon(R) E-2276M CPU @ 2.8 GHz With Nvidia Quadro T2000 If you use this you will need to disable Intel(R) UHD Graphics 630 it will try to use this card to extend battery life. I also have 3 - Logitech 930 Web camera attached to each DuraMax and plunged in to the computer. I use IT tools to remote in to any machine anywhere in the world Home Screen of Autorun Next 2 are different angles 930 cameras from Queretaro Mexico Next is from Shanghai China And 3D printer in my office that just printed a intake manifold for a High speed camera.Capture4.PNGCapture3.PNGCapture2.PNGCapture1.PNGCapture.PNG Link to comment https://qualityforum.zeiss.com/topic/12684-laptop-that-works-great-with-calypso/ Share on other sites More sharing options...
[Is...] Posted June 4, 2020 Share Posted June 4, 2020 Did you notice that your laptop doesn’t achieve the minimum recommendations from ZEISS: Link to comment https://qualityforum.zeiss.com/topic/12684-laptop-that-works-great-with-calypso/#findComment-63494 Share on other sites More sharing options...
[Is...] Posted June 4, 2020 Share Posted June 4, 2020 ... Link to comment https://qualityforum.zeiss.com/topic/12684-laptop-that-works-great-with-calypso/#findComment-63496 Share on other sites More sharing options...
[Da...] Posted June 4, 2020 Author Share Posted June 4, 2020 Please sign in to view this quote. You just sent a processor spec. Its using a 6 core processor 12 threads Works great I would rather have 6 cores at 2.8 then 4 cores at 3.1 But really non of that much matters calypso only uses 30% of the processor It is all about the T2000 Nvidia Card. M2000 on the Left and T2000 on the rightCapture.JPG Link to comment https://qualityforum.zeiss.com/topic/12684-laptop-that-works-great-with-calypso/#findComment-63498 Share on other sites More sharing options...
[Da...] Posted June 4, 2020 Author Share Posted June 4, 2020 "The lady doth protest too much, methinks" Zeiss Performance test? Once again Eric Oberg you just need to use your own account. Link to comment https://qualityforum.zeiss.com/topic/12684-laptop-that-works-great-with-calypso/#findComment-63500 Share on other sites More sharing options...
[Is...] Posted June 4, 2020 Share Posted June 4, 2020 🙄 Link to comment https://qualityforum.zeiss.com/topic/12684-laptop-that-works-great-with-calypso/#findComment-63502 Share on other sites More sharing options...
[Ri...] Posted June 4, 2020 Share Posted June 4, 2020 Unless you have complex programs (Curves, Free-Form Surfaces, a lot of PCM calculations) I don't recommend high-end computers for a DuraMax. I use a Dell Precision 7720 for my offline programming, and it works well. Zeiss uses a modified version of this laptop for their entry level Comet/T-Scan systems which is processing a lot of data. At the end of the day, find something that works well for you, and meets your budget. Link to comment https://qualityforum.zeiss.com/topic/12684-laptop-that-works-great-with-calypso/#findComment-63504 Share on other sites More sharing options...
[Is...] Posted June 4, 2020 Share Posted June 4, 2020 my best Performance Computer is € 800, by the way (N.B. I only use PCM and Curves) Link to comment https://qualityforum.zeiss.com/topic/12684-laptop-that-works-great-with-calypso/#findComment-63506 Share on other sites More sharing options...
[Is...] Posted June 4, 2020 Share Posted June 4, 2020 Please sign in to view this quote. I would say that depends more of the overload of the CMM.. I have cases of people asking for more CMMS because they are overloaded; when we study some cases, we notice that they have computers that takes lot of time processing. I have seen one case where one single measuring was taking around 30% more just because the workstation Link to comment https://qualityforum.zeiss.com/topic/12684-laptop-that-works-great-with-calypso/#findComment-63508 Share on other sites More sharing options...
[Ch...] Posted June 4, 2020 Share Posted June 4, 2020 I did a study to justify spending money on faster computers. I timed some programs from start to finish on both our slower computer and our fastest. equation was as follows (( Time difference between programs in hours * number of times ran per year) * $$per hour to run the CMMs) = money saved just by upgrading computers per year Link to comment https://qualityforum.zeiss.com/topic/12684-laptop-that-works-great-with-calypso/#findComment-63510 Share on other sites More sharing options...
[Da...] Posted June 4, 2020 Author Share Posted June 4, 2020 Just a Suggest after testing 6 different computers The Zeiss Laptop has a Model issues with it when you try to extract anything. On large models Link to comment https://qualityforum.zeiss.com/topic/12684-laptop-that-works-great-with-calypso/#findComment-63512 Share on other sites More sharing options...
[Is...] Posted June 4, 2020 Share Posted June 4, 2020 Please sign in to view this quote. That issue is normally more related with configuration of the graphic card: viewtopic.php?f=13&t=2349&hilit=Graphic+card Link to comment https://qualityforum.zeiss.com/topic/12684-laptop-that-works-great-with-calypso/#findComment-63514 Share on other sites More sharing options...
[Da...] Posted June 5, 2020 Author Share Posted June 5, 2020 Zeiss Setup that HP laptop just to let you know Here you go Eric the Test you asked for 216 Seconds Only used 18% of Xeon CPUCapture.PNG Link to comment https://qualityforum.zeiss.com/topic/12684-laptop-that-works-great-with-calypso/#findComment-63516 Share on other sites More sharing options...
[Da...] Posted June 5, 2020 Author Share Posted June 5, 2020 New Desktop PCCapture4.PNG Link to comment https://qualityforum.zeiss.com/topic/12684-laptop-that-works-great-with-calypso/#findComment-63518 Share on other sites More sharing options...
[Is...] Posted June 5, 2020 Share Posted June 5, 2020 Please sign in to view this quote. Thanks, this is very helpful.. I have the impression that the problem in my computers is related to the installed policies of my company.. Could you check with Calypso 2018? Link to comment https://qualityforum.zeiss.com/topic/12684-laptop-that-works-great-with-calypso/#findComment-63520 Share on other sites More sharing options...
[Da...] Posted June 5, 2020 Author Share Posted June 5, 2020 I want to try it on my 22 Core Intel Xeon Gold it has 44 Threads if it is processing power it should do it in 58 Seconds 3.0 GHz speed That will also depend on if it can use all 22 cores Link to comment https://qualityforum.zeiss.com/topic/12684-laptop-that-works-great-with-calypso/#findComment-63522 Share on other sites More sharing options...
[Ni...] Posted July 7, 2020 Share Posted July 7, 2020 My question is, where do you get the money to get all of that stuff? 😮 I would love to add cameras on our machine at work and a 3D Printer at home lol Link to comment https://qualityforum.zeiss.com/topic/12684-laptop-that-works-great-with-calypso/#findComment-63524 Share on other sites More sharing options...
[Ia...] Posted July 8, 2020 Share Posted July 8, 2020 Please sign in to view this quote. Some companies actually put money into their quality/metrology department. Crazy, I know. Link to comment https://qualityforum.zeiss.com/topic/12684-laptop-that-works-great-with-calypso/#findComment-63526 Share on other sites More sharing options...
[An...] Posted July 8, 2020 Share Posted July 8, 2020 Investments are also necessary, there is no point if the customer can measure better than the supplier. Link to comment https://qualityforum.zeiss.com/topic/12684-laptop-that-works-great-with-calypso/#findComment-63528 Share on other sites More sharing options...
[Da...] Posted September 18, 2020 Author Share Posted September 18, 2020 New Desktop computer I just built a Desktop that can do the PCM program in this thread in 116 Seconds Motherboard - - - Asus Prime Z490-A LGA 1200 Intel Z490 SATA 6Gb/s -- $229.99 Processor - - - i7-10700 Intel Core i7-10700 -- $319.89 Cooling Water System - - - ID-Cooling AURAFLOW x 360 CPU water cooler 115X/2066 -- $89.99 Outer Case - - - Fractal Design Meshify C white Tempered Glass -- $89.99 Ram - - - 4 X G.Skill Pipjaws V Series 16 GB -- $58.99 Hard Drives - - - Western Digital Blue SN550 M.2 2280 1 TB PCI-Express 3.0 X 4 -- $104.99 Power supple - - - Rosewill LEPTON 600 Modular 600W -- $99.99 Graphics card - - - Nvidia RTX 2080 Cost -- $1200 The new Nvidia cards that are coming out are only $400 to $650 and much faster. Nvidia RTX 3060 - 3070 - 3080 Total was Computer was $987.00 Total with Nvidia RTX 2080 Cost $2187.00 Total with the new Nvidia RTX 3070 Cost $1487.00 will test when I get the new Card Link to comment https://qualityforum.zeiss.com/topic/12684-laptop-that-works-great-with-calypso/#findComment-63530 Share on other sites More sharing options...
[Ri...] Posted September 18, 2020 Share Posted September 18, 2020 Is that a 2080Ti because that sounds expensive for a normal or super 2080. Link to comment https://qualityforum.zeiss.com/topic/12684-laptop-that-works-great-with-calypso/#findComment-63532 Share on other sites More sharing options...
[Da...] Posted September 18, 2020 Author Share Posted September 18, 2020 Nvidia RTX Ti super are all over the place for cost. The new Nvidia that just come out are 1/2 the price for much faster graphics card The new 3080 is about $700 that out is better then the TRX 2080Capture.JPG Link to comment https://qualityforum.zeiss.com/topic/12684-laptop-that-works-great-with-calypso/#findComment-63534 Share on other sites More sharing options...
[Ri...] Posted September 18, 2020 Share Posted September 18, 2020 Good luck getting anything Series 3 unless you have bots to help you. Lol. Link to comment https://qualityforum.zeiss.com/topic/12684-laptop-that-works-great-with-calypso/#findComment-63536 Share on other sites More sharing options...
[Ia...] Posted September 18, 2020 Share Posted September 18, 2020 Please sign in to view this quote. Good luck acquiring one. The initial stock was sold out internet wide in under 5 minutes. Bots probably claimed 95% of them. I tried newegg, best buy, and Nvidia's own site. Instantly went from "Notify me when available" to "out of stock". Newegg claimed there was more traffic than on black friday. I only want it for video games though 🧑💻 Link to comment https://qualityforum.zeiss.com/topic/12684-laptop-that-works-great-with-calypso/#findComment-63538 Share on other sites More sharing options...
[Da...] Posted September 18, 2020 Author Share Posted September 18, 2020 Yes it will take time to purchase one. I am waiting of for the RTX 3070 but that could take some time. The P4000 have also work great Cost $749.00 Nvidia Quadro P4000 Link to comment https://qualityforum.zeiss.com/topic/12684-laptop-that-works-great-with-calypso/#findComment-63540 Share on other sites More sharing options...
