Profile result
We have a program written by someone else The print calls out a .003 surface profile to -A-. There are two basic dimensions
(.0505 & .0140) that control the profile in X & Z. We report the basic actuals as reference to the operator to make
adjustments. We ran two parts, one showed .0506 & .0136. The second part was .0506 & .0135, but the profile actuals reported at .0024 & .0028 & .0013 & .0005 respectively. I would think that all things being equal, both (parts) profile actuals would be within .0001. Can anyone explain this?
The basic dimensions say nothing about the form of the surface, so it's possible the features' LSQ evaluations made them look the same, even though one was rougher/wavier/whateverer than the other. It's hard to say without seeing.
This is why trying to report basic dimensions for a Profile characteristic can be dangerous.
Even something as simple as a linear dimension can show "weird" results because the Profile is measured to a DRF and not a single datum/feature.
It all depends on purpose of profile check and constrains. It's not bad if you have only one base for profile, but it's bad if purpose of check looks like you need more bases than one ( bad drawing ).
I think additional printout information,can help you.It gives the co ordinate value Zeiss used to calculate profile.
