[Me...] Posted May 13, 2021 Share Posted May 13, 2021 Anyone know how to go back to the default window size for the printout that pops up on the screen after a run? Link to comment https://qualityforum.zeiss.com/topic/12694-custom-printout-window/ Share on other sites More sharing options...
[Ri...] Posted May 13, 2021 Share Posted May 13, 2021 PiWeb Reporting > Custom Printout.............. Fight me.... 🤬 🤬 🤬 Link to comment https://qualityforum.zeiss.com/topic/12694-custom-printout-window/#findComment-63604 Share on other sites More sharing options...
[Me...] Posted May 13, 2021 Author Share Posted May 13, 2021 Please sign in to view this quote. Eventually I will probably agree, but I can't change our company's report yet. In the mean time this a very annoying problem. Link to comment https://qualityforum.zeiss.com/topic/12694-custom-printout-window/#findComment-63606 Share on other sites More sharing options...
[Da...] Posted May 13, 2021 Share Posted May 13, 2021 On the measurement tab go to multiple report and uncheck "multiple reports active" (top left) and you've turned off PiWeb ! Link to comment https://qualityforum.zeiss.com/topic/12694-custom-printout-window/#findComment-63608 Share on other sites More sharing options...
[Dy...] Posted May 13, 2021 Share Posted May 13, 2021 I cant seem to mimic that but try changing the report printout under - Resources - define report - custom report tab and changing it to something else applying the changes and then changing it back?? Link to comment https://qualityforum.zeiss.com/topic/12694-custom-printout-window/#findComment-63610 Share on other sites More sharing options...
[Me...] Posted May 13, 2021 Author Share Posted May 13, 2021 Please sign in to view this quote. Tried, tried again and failed. Our company predominantly uses 2017 and it seems to work for my offline seat when I go and change the vphead.gra file, but when I went out to the machine and tried to replicate the solution, it would NOT work. I gave up 🙁 Link to comment https://qualityforum.zeiss.com/topic/12694-custom-printout-window/#findComment-63612 Share on other sites More sharing options...
[De...] Posted June 17, 2021 Share Posted June 17, 2021 The only conclusion I can come to is: Extras > Settings > Environment > Dialogs > Open under the mouse pointer Selecting the "open at last position" allows you to be able to position the window wherever you want, and size the window. Changing to "open under the mouse pointer" has reverted it. Link to comment https://qualityforum.zeiss.com/topic/12694-custom-printout-window/#findComment-63614 Share on other sites More sharing options...
[Me...] Posted June 18, 2021 Author Share Posted June 18, 2021 I found out where to customize this. Open User Defined Printout and then the "frame.gra" file and you can adjust that page size but it's extremely finnicky Link to comment https://qualityforum.zeiss.com/topic/12694-custom-printout-window/#findComment-63616 Share on other sites More sharing options...
