Screen recording
At home, do you have off line license?
Anyway thanks for your reply. What about Active Presenter?
It's a free download. Install, reboot. Viola'.
it's the only one I've tried. Met my needs. Records everything on the screen. Mouse movements, everything.
I have used OBS Studio to record things in Calypso for training/demonstration purposes. It works.
I'm sure there are other options but I'm familiar with OBS from using it at home.
Make sure you set the source to be your monitor if thats what you want, not just the calypso window otherwise it will only record that window.
You can also use the Microsoft Power-Point software if you have it. Go to insert at the top and you'll see screen capture in one of the icons. I've used it to record Calypso running in simulation.
