[Sa...] Posted June 26, 2020 Share Posted June 26, 2020 Hello, I would like to find the min and max values of similar characteristics by part. i.e. one part we run has 6 similar #4 inner diameter characteristics, each have the same spec. Is it possible to find the overall min and max from the six from a specific part (S/N 55-1234) through piweb? If the six #4 characteristics return values like (.5853, .5860, .5855, .5853, .5831, .5859) I want a section that says #4 Inner diameter for S/N {55-1234} [min: .5831] [max: .5860] Instead of sorting through the data manually. Link to comment https://qualityforum.zeiss.com/topic/12734-minmax-similar-characteristics-per-part/ Share on other sites More sharing options...
[SH...] Posted July 5, 2020 Share Posted July 5, 2020 You can do it in using min max characteristic.. Link to comment https://qualityforum.zeiss.com/topic/12734-minmax-similar-characteristics-per-part/#findComment-64020 Share on other sites More sharing options...
[Sa...] Posted July 6, 2020 Author Share Posted July 6, 2020 Please sign in to view this quote. The min max characteristic only returns min and max per characteristic, instead of a combination of all similar characteristics. Unless I have it mixed up, I don't believe this is the answer I seek. Link to comment https://qualityforum.zeiss.com/topic/12734-minmax-similar-characteristics-per-part/#findComment-64022 Share on other sites More sharing options...
[ba...] Posted July 10, 2020 Share Posted July 10, 2020 Use a characteristic attribute to flag characteristics of certain types. I.e., Flange diameters, Flange Widths. Then use an inspection plan filter where characteristic flag = Flange diameter and apply that to your text box where you do your mathematical expression or calculation. Link to comment https://qualityforum.zeiss.com/topic/12734-minmax-similar-characteristics-per-part/#findComment-64024 Share on other sites More sharing options...
[Sa...] Posted June 10, 2021 Author Share Posted June 10, 2021 Please sign in to view this quote. Laura, Is the inspection plan filter in calypso? or is it on the piweb side of it? Link to comment https://qualityforum.zeiss.com/topic/12734-minmax-similar-characteristics-per-part/#findComment-64026 Share on other sites More sharing options...
[ba...] Posted June 10, 2021 Share Posted June 10, 2021 I re-read your original request, and it probably makes the most sense to use Minimum Result or Maximum Result under Size > More. Use group names to section off your characteristics in the StandardProtocol with a subtitle. You can Mark the individual characteristics OFF so that they don't report each diameter individually. With my original response, I think I misunderstood you. Thanks Laura Link to comment https://qualityforum.zeiss.com/topic/12734-minmax-similar-characteristics-per-part/#findComment-64028 Share on other sites More sharing options...
[Sa...] Posted June 11, 2021 Author Share Posted June 11, 2021 Laura- That is exactly what we are doing now. Thank you. Link to comment https://qualityforum.zeiss.com/topic/12734-minmax-similar-characteristics-per-part/#findComment-64030 Share on other sites More sharing options...
