Datum precidence
Datum feature simulater of datum B might not constrain rotational degrees of freedom, it depends upon on how the part function.
As I see it:
A.B.C would have origins at A and B and planar from C
A.C.B would have origins at A,B, and C and planar from C
Tolerances ideally should reflect the function of the datum surfaces, but we don't have this information
This is simply a hand held instrument. The finished product has 3 spheres attached to (D1, D2, D3).
These spheres are picked up by a camera system used by a robot for targeting were to cut or drill.
Designers need to start explaining what they actually want.
Maybe something like attached would help with this. Just spell it out.
Either A|B|C or A|C|B are legitimate design decisions. Without information on the design intent, it is hard to recommend one over the other.
Personally, from a functional point of view, I would make B the pattern of holes, and call out a profile to A|B for the tip of "C". That probably best represents the described design intent.
Yep ISO 5459. Taken from book from 2019 Geometric tolerances by ISO GPS Author Ing. Karel Petr, Ph.D.
Y14.5-2009 has one too - the "datum translation symbol" AFAIK, it is the same effect. It is a sideways triangle. 1132_cb71d1738cca0c92c48d1f570e0f7991.png
