Does Calypso have a function for measuring arc length?
I am measuring a part and the drawing calls for arc length. I looked in the user guide but don't see a function for arc length. Is there one?
Your formula may need some modification(s) to account for the actual angle in radians but put a corrected formula in a Result Element and it will work just fine.
  • 2 weeks later...
You can do a formula in any feature characteristic, just create a random feature you can make it theoretical and then right click one of the fields under nominal (like your x,y,z,d boxes) and choose formula, there you can input whatever formula you want and then check the box on so it gives you the result in characteristics that way it will be on your report.
  • 11 months later...
If you use result element set to length or number the formula should be simply radius * angle because the angle is already in radians.
