Pallet in autorun
Hello
I want to measure components with 2 different sets of tolerances A and B on a 32 stations pallet
I've done this:
if getRecordHead("palletlocationnumber") == getRecordHead("firstpalletlocationnumber") then
mypath=getActualInspectionDir()+"\parameter\"
myrunlist=inquireList("Please select","Tool A","Tool B")
if myrunlist==""
message("operator has cancelled")
endInspection()
else
readPCMFile(mypath+myrunlist+".para")
message(myrunlist+" tolerance set have been loaded")
endif
endif
redrawCAD()
And it works fine... for the first part of the pallet after that routine goes back to parameters saved.
Is there a way to make calypso to keep parameters loaded with the first part so the operator does not have to confirm choice 32 times each 90 seconds?
Save the choice to a temporary file that you run if getRecordHead("palletlocationnumber") <> getRecordHead("firstpalletlocationnumber").
Something like this: I probably missed something but I think you get the idea.
//defines paths
Path_tempFile = "C:\temp\choice.txt"
//conditional delete of temp file
deleteFile(Path_tempFile)
endif
//inquires for myrunlist and stores it if the file is missing. Runs the file if it is present.
if fileExists(Path_tempFile) == false
addToFile(Path_tempFile,"myrunlist = " +qm() + myrunlist +qm())
else
runPCMFile(Path_tempFile)
endif
//Sets parameters according to choice or stored file.
if myrunlist==""
endInspection()
else
display(myrunlist+" tolerance set have been loaded")
endif
redrawCAD()
