Angularity
For the example of this cylindrical part:
Datum E - Cylinder: is defined as the OT Surface, or the Centerline of the Cylinder?
Datum D - is the Face of the Cylinder
How would you check this feature without the benefit of a CMM?
Would you trust a result (repeatability) with such a small angular surface to evaluate?
What is the Max/Min probe size that you would recommend?
(Per ASME Y14.5, latest revision)
Thanks all!
1mm probe or larger will work fine. I usually program this type of angle, instead of trying to touch it manually. While it looks tight, the tolerance is actually quite large when compared to the length of the cone. Program as if the cone was at low limit, this allows a low limit part to be checked . If you program a mean, or high limit part, you might find it completely misses a low limit part.
