[Ro...] Posted June 2, 2021 Share Posted June 2, 2021 Hi guys, i have to measure the depth of a stamped surface located on a big radi (R220) As you can imagine the stamped surface doesnt really look like the model, so i cant just use a line and a circle and get an intersection. My goal was to scan the stamped area like this, turn it 45° degrees, get the max point, turn it back and get the distance to the flat part. I've tried a lot, but i can't get it to work. Does anybody of you guys have an idea how i can obtain the right value with little as possible error? Link to comment Share on other sites More sharing options...
[Da...] Posted June 2, 2021 Share Posted June 2, 2021 This is such a poorly designed dimension. If it was at low limit, I'm pretty sure it would not exist on the shallow side of the spot face. A dimension back to part of the DRF would be more appropriate. Since you have a model, you could use space points to determine deviation on the face and around the hole. Then with a bit of math , determine the depth that way ? Link to comment Share on other sites More sharing options...
[Er...] Posted June 3, 2021 Share Posted June 3, 2021 I would take a plane on the spot face. Then create a Step Point at the corner. A small plane on the R220 and a line over the edge of the R220 should do it. Change the Step Point settings until it matches a secondary measurement method. Link to comment Share on other sites More sharing options...
