Units switching
We have a couple of different users for our O-Inspect and we are having trouble with it switching the units for the different users. We have assigned the unit to the program, but when we setup the program in the AutoRun it sometimes switches between which user is logged on.
How can I make sure that it is running in the correct unit in the AutoRun no matter who is logged in?
  • 2 weeks later...
We have been running into the same Issue at our work place, where the program will be set in the to a specific "Length Unit" in the software itself but the User will sometimes override this setting in the program and go off of the global settings. Any one have any ideas?
I have Autorun locked down to prevent "accidents." To the point all a user can do is run a part. Very few checkboxes are checked and I ignore the Recommended settings.
In Calypso
Pulldown menu
Extras-Settings-User
Log in as Master
Tabs at the bottom let me switch between Users.
Units is under Environment, this should not be checked under Privileges or Autorun Rights.
Hopefully this works for you.
