Moving CAD Model & Characteristics and Features
Hello Everyone,
I am wondering if there is a way to move the CAD model along with its programmed characteristics. I want to reposition a part in the Planner Mode, but whenever I move the part model the characteristics and features already programmed do not move with it. Is there a way to get around this?
Thank you!
Use the Special Button in the Base Alignment to rotate or translate as needed. Typically, after I do that, I go back and select Create New Base Alignment and select the base alignment features that are now in their new position (without using the Special button)
Double-check your clearance cube as it may have moved.
