Gauge Correction evulation method
Hello,
I'm trying to use gage correction evulation method on cylinder liners. I'm new to this method. I have a couple questions about the topic. Would help a lot if you could answer it.
1- İs it possible to add two different gage correction data on Calypso (for different dimensions), will the first gage correction date going to be erased if i install another gage correction data?
2- I've been told that i should use ring master that bigger than the dimension im going to measure. What should be the difference between the dimension im going to measure and ring master. ( both ideal difference and max. difference)
3-If i were measure the outer diameter on part, does ring master have to be grinded by outer diameter? Can we use the ring master that grinded by inside diameter?
4- Does it change anything to select filtering method? If i were going to use minimum circumscribed circle method to evaluate the liner, can i use LSQ method while programming gage correction
