[Ri...] Posted May 26, 2021 Share Posted May 26, 2021 I received this error after installing Solidworks 2021. I have uninstalled Claypso Re-installed Calypso. And I have tried to use the "Simulation" tab in CMM configuration (Reports the same error). Note: While in CMM Configuration dialog window, if I select "Stylus System" it generates a system error. Status window Please sign in to view this quote. SDCOconnnect.log (Is not being generated in the "Simulation" folder, its in the Spectrum folder. The above error notice states the "Simulation" folder.). The software uses the Spectrum "CMM configuration". Please sign in to view this quote. Error report Please sign in to view this quote. CMM Configuration.jpg Link to comment Share on other sites More sharing options...
[Ri...] Posted May 26, 2021 Author Share Posted May 26, 2021 Probable fix. The SQL Server Agent (SCDO) was "stopped". Setting this to Automatic (hope it works in the future). Start the service and I was able to start Calypso and connect.SQJ Server Agent (SCDO).jpg Link to comment Share on other sites More sharing options...
[Cl...] Posted May 26, 2021 Share Posted May 26, 2021 I had to delate ALL the SQL servers prior to installing Calypso 2020. Link to comment Share on other sites More sharing options...
