Why are my curve points offset from the model?
Is this just how its displays the vectors? I notice the points seem to be correct but it shows up this way. Curve was made straight from model and only edits I did were point densities.
I don't know what and how looks your fixture or part, but this happened to me, when i used stored alignment and didn't measured correct one on part ( due some reasons ).
So your fixture is not stable, or part is made like this way - any big difference will result in this situation.3001_623978b7e24c2b78e119ff731c42ad13.png
When you show Display Measured Points on a curve, they represent probe center. Select Show Deviations, you will see the actual points. It might help to un-select Show Nominal Points.
