Best fit of imported data
We are attempting to create a best fit alignment for the imported hole data from the component (theoretical in program) and aligning this to the measured data of the actual holes within the fixture.
We have created intersection points at front and rear of the fixture measured data and also the same for the imported hole data. The things that need to be considered is the holes are at different angles and also the fixture data and imported data are at different heights.
Which would be the best method to align using this data?
