Composite True Postition/Naming of Characteristic
Is there a way to name individual features in the best fit true position characteristic? Also for individual features in a pattern...
No, but if you need to. You can create separate Position characteristics that evaluate each feature individually, and you will use the Best Fit Bore Pattern as the alignment.
