[Mi...] Posted May 7, 2021 Share Posted May 7, 2021 Hi, I am looking for some recommendations on how to program the alignments for a part. We are running a new part and we are continuing to have kick outs and we believe this is do to the alignment. We manual checked the features and they are good but in the program the TP is out in the Z. I posted what I could without reveling to much. I created a line between b1 and b2, is this the correct/recommended way? (this is a casting) TIASNIPPED CAD VIEW.pngSNIPPED ALIGNMENT VIEW.pngSNIPPED CASTING PRINT.png Link to comment https://qualityforum.zeiss.com/topic/12958-alignment-3-2-1/ Share on other sites More sharing options...
[Ma...] Posted May 7, 2021 Share Posted May 7, 2021 I don't know if it would make any difference, but i would take 2 plane points and use 3D line with recall ( not recall points ) instead od 2D line. Link to comment https://qualityforum.zeiss.com/topic/12958-alignment-3-2-1/#findComment-65580 Share on other sites More sharing options...
[Te...] Posted May 10, 2021 Share Posted May 10, 2021 You should NEVER use a 2d Line for recall or recall feature points it will give you wrong answers. GOOD RULE OF THUMB: 2D Line - ALWAYS Measured 3D Line - ALWAYS Theoretical (recall or recall feature points) Link to comment https://qualityforum.zeiss.com/topic/12958-alignment-3-2-1/#findComment-65582 Share on other sites More sharing options...
