[Ma...] Posted May 4, 2021 Share Posted May 4, 2021 Is there a way to change how measured points are named instead of using "Incremental Part Number"? I created a userfield called "Lathe Code" that has a dropdown of different lathe combinations we use for naming of our part runs. I have PiWeb reports saving to a directory using the lathe code and date. I removed "Incremental Part Number" from the Input Parameters. When trying to use Subsequent Evaluation it is showing incremental numbers. Is there an option to select my Lathe Code field for the naming of measured points? Link to comment Share on other sites More sharing options...
[Ri...] Posted May 5, 2021 Share Posted May 5, 2021 Please sign in to view this quote. Yes - in Resources - Name for output files - for this Measurement Plan You can select Measuring points from the Output File dropdown. Then checkmark Name of output file variable. You can also setup a global setting to use. Here is an example of the one I have setup. Link to comment Share on other sites More sharing options...
[Ma...] Posted May 5, 2021 Author Share Posted May 5, 2021 Awesome! Exactly what I was looking for. Thanks for the help Link to comment Share on other sites More sharing options...
[Ch...] Posted May 6, 2021 Share Posted May 6, 2021 Please sign in to view this quote. very helpful, I figured this should be doable, since our company does not use "incremental part number". One thing I noticed is : in the name definition you have "Date : , but below it shows Date___ ; same for Time. Not a huge deal, Calypso probably won't allow semi-colon, huh? Thanks again. Link to comment Share on other sites More sharing options...
[Ch...] Posted May 6, 2021 Share Posted May 6, 2021 Please sign in to view this quote. Semi-colons are allowed Link to comment Share on other sites More sharing options...
[Ch...] Posted May 6, 2021 Share Posted May 6, 2021 Please sign in to view this quote. Right, I meant colon " : " . Long day. Thanks, I'll give this a shot. Link to comment Share on other sites More sharing options...
