[Jo...] Posted August 23, 2022 Share Posted August 23, 2022 Hello Team, I was just asked to interpret some drawings from Inventor but I do not have the necessary software to open up .dwg files. That being said, can ATOS import and interpret the required information in .dwg files so that I may have access to the information presented to me via inventor? If not, what alternative files type should I ask to receive all necessary data? Including PMI. I wonder if it is a matter of having the right front end interpreter to elements in the .dwg file that fall under PMI data. Link to comment https://qualityforum.zeiss.com/topic/1298-dwg-file-import-with-pmi/ Share on other sites More sharing options...
[Ja...] Posted August 24, 2022 Share Posted August 24, 2022 Hello , gom software does not support .dwg , this is a 2D format. In the help area of the software search for 'CAD import' this provides a helpful guide on what is supported, including PMI within format. Link to comment https://qualityforum.zeiss.com/topic/1298-dwg-file-import-with-pmi/#findComment-4224 Share on other sites More sharing options...
[Na...] Posted August 24, 2022 Share Posted August 24, 2022 There is also an article in the FAQ regarding PMI import: https://connect.gom.com/pages/viewpage.action?pageId=47554265 Link to comment https://qualityforum.zeiss.com/topic/1298-dwg-file-import-with-pmi/#findComment-4226 Share on other sites More sharing options...
