[Ra...] Posted May 4, 2021 Share Posted May 4, 2021 I have a simple rod that was was spacing out and taking circles uniformly over the length and displaying the dia. If i use a helix path , that will save me time and effort. To display the diameter im using the diameter characteristic. Will this take a average ,min or max value ? How can i then determine if a area is out of spec, where that area is on the rod. Thank you. Link to comment Share on other sites More sharing options...
