Edit standard hdr.txt file
Is it somehow possible to edit the standard configuration on the hdr.txt file which is generated when "Result File" is on?
I am not interested in adding a user field as I would have to turn it on in all of the programs that has already been done.
Is the template hidden somewhere?
Would be interested in hearing this as well.
I have a customer who has a script that they run that puts it into the format they need, but would be nice if it was something that could be handled (without PCM) natively.
At the end of the week Zeiss Application Engineering will take a look and see if it is possible. He believe it should be possible, but maybe the Germans have to be involved.
