Caliper distance
I'm trying to measure the max and min distance on a plane relative to another plane. I tried using a caliper distance and set the considered feature to Measured Points and the Reference Plane to Outer Tangential. When I go into CAD Evaluation, I see a point indicator on both planes. When I activate tolerance zone, they appear on both planes.
The screenshot below seems to show result of top plane. I really don't understand what is going on.
Any ideas or suggestions?
Bottom line. I'm trying measure the depth of a pocket. I would like to be able show the max and min points relative to the top plane, which is not my Z origin or Spatial feature.
Not sure how well this will work, but, can you construct a perpendicular from your ref plane to the other plane ( OTF then ITF ) and ask for length of perpendicular ?
The only reliable way we have come up with to get the result you are looking for is to:
-Create a new alignment using the reference plane as the primary datum.
-Make a new plane recalling the feature points from the plane to evaluate referencing the new alignment
-Construct Min and Max coordinate feature from the new plane and compare these to the tolerance
