[Ra...] Posted April 28, 2021 Share Posted April 28, 2021 I have two planes that are parallel to each other. Using poly line to take points across the two separate planes. Then I'm using caliper distance to take the distance between the two planes which is called out on a print(Max Caliper Distance). My Question is how do you determine which area is out of spec. Can i form a graph from caliper distance or is there another better way ? Link to comment https://qualityforum.zeiss.com/topic/13028-question-regarding-two-plane-measurements/ Share on other sites More sharing options...
[Ma...] Posted April 28, 2021 Share Posted April 28, 2021 Please sign in to view this quote. I would set up a profile that is to symmetry of the two planes for which you can then do CAD presentation for. Link to comment https://qualityforum.zeiss.com/topic/13028-question-regarding-two-plane-measurements/#findComment-66000 Share on other sites More sharing options...
