Collision with space point probing.
Hello,
I am a new Calypso user, there is a issue with space point probing. I am inspecting a big plastic part with big deviation(estimated about +8 mm). retract distance set 20 mm;. while probe moves to the space point along retract distance, program stopped running and showed information "33 Collision lost of commands possible". I guess there should be a effective probing range for space point. Maybe +8 mm deviation is out of the range. How to reset the range or any other solution?
Thanks for help in advance!
Are you actually running the part on the CMM or in simulation?
I guess it could be the search distance before or after setting but, I don't think that would cause a collision error?
You can go to the measurement plan editor features click the drop-down menu and select probing and there you can set the distance before and after the nominal.
I'd also set the clearance distance to Zero.
