Speed too high
I get the speed message on several features while programming, not any one type in particular. I've experimented with slowing down the speeds and/or changing data densities but it still keeps popping up. There doesn't seem to be a way of clearing the notification once it pops up so I'd like to turn it off altogether.
Not a true answer to your question, but maybe it sheds a little light on what's happening.
"Speed Subsequently Too High
In certain cases, it may occur that the measurement results to be used for characteristic evaluation were recorded at an excessive speed. As a result, it will not be possible to achieve the desired accuracy. This can occur in the following cases:
(A) You create a new characteristic after a measurement has already taken place.
(B) You would like to evaluate a characteristic that is not contained in the list of characteristics of the measurement.
CALYPSO checks the speed at which the measurement was performed. If this speed is too high for the new characteristic, the following message will appear:
'The speed used is too high for this Characteristic evaluation! Please measure the Feature again!' In this case, you will have to repeat the CNC run including the characteristic in question. The optimum speed will be re-determined taking the characteristic into consideration."
Go into the strategy of one of the problem features. In the (speed, step width, points per section) area there is a tab at the top. CALCULATE , select that and see if it recalculates your speed or point density. This is the recommended speed, and I believe there also is a global setting over this.
