MMC on threads
From section 2.9 of Y14.5-2009,
"Each tolerance of orientation or position and datum reference specified for a screw thread applies to the axis of the thread derived from the pitch cylinder."
THe problem is not that you can't measure the minor diameter accurately, but that you can't measure the pitch diameter accurately.
Pitch cylinder is a tall order 😮 . I have witnessed drawing that is clearly specified tp for minor diameter ,don't remember it was ASME or ISO.
Agreed.
Yes, that was likely done to accomodate the limitations of available measuring equipment and methods.
Thanks for sharing, Shabu. I have had the same issues with position for threads. Have you ever tried flexible hole locators? They're an extra expense, but sometimes we can persuade the customer to provide them as a tooling expense during the quoting process.
Here's an example:
https://www.mscdirect.com/browse/tnpla/ ... G3EALw_wcB
I have used both styles of Threaded Hole Location gages (solid & split types, from different manufacturers), and have gotten good correlation between them.
Also, we were able to get good correlation on a between my measurements, and two different suppliers; each using a different brand of gage.
The split types are nice, because you don't need to worry about over-tightening them, as they do not need to be tightened to the shoulder, to be accurate and effective. The drawback of the split types, is the difficulty of finding someone who can calibrate them; of course, you can always treat them as a disposable item, and just throw them away after a specific time, or amount of use.
*Note* we only use Threaded Hole Location gages on tapped holes that are too small to probe the pitch diameter, directly. I have not had the opportunity to test direct measurements vs Threaded Hole Location gages.
