[Wo...] Posted April 6, 2021 Share Posted April 6, 2021 Hi, I'm sure that it has been mentioned before, but I can't find anything. Maybe on the old forum. I have a Position req. on a inspection gauge ball that's placed in a cone. Any suggestions how to achieve that? Datum B is the ID of the part, Datum C is a slot that's responsible for clocking the part. I'm not worried about getting MMC bonus for now, just how to build the construction to virtually measure it. Any help is appreciated, Wojtek Link to comment Share on other sites More sharing options...
[Ri...] Posted April 6, 2021 Share Posted April 6, 2021 You could make two opposing lines, and use the Construction Tangent Function. Or you could measure the Cone, and use Trig to calculate the ball sitting in there virtually as well. Link to comment Share on other sites More sharing options...
[Mi...] Posted April 6, 2021 Share Posted April 6, 2021 Only tangentially (hah) related, but: how would you apply the MMC to this callout? Not just in Calypso, I'm having trouble visualizing conceptually what they even mean. Link to comment Share on other sites More sharing options...
[Ri...] Posted April 6, 2021 Share Posted April 6, 2021 Please sign in to view this quote. Some people just like to watch the world burn. Link to comment Share on other sites More sharing options...
[Ch...] Posted April 6, 2021 Share Posted April 6, 2021 It's a standard probe size, get one in 1-2 days. Use self-centering point with midpoint evaluation. We have a lot of these 'ball ramps'. It can be done with constructions and formulas as well. good luck. Link to comment Share on other sites More sharing options...
[Wo...] Posted April 7, 2021 Author Share Posted April 7, 2021 Please sign in to view this quote. I have used two opposing lines for now, seems to have done the trick. Interestingly, there is another callout on this countersink - Position with MMC on its diameter. Chris, for now its just a one off prototype. If the thing goes into production I will definitely consider buying a probe. Thanks! Thank you all for the help! Link to comment Share on other sites More sharing options...
[Jo...] Posted April 7, 2021 Share Posted April 7, 2021 Could you make an alignment using Datums, Create a THEO Sphere with BASIC distance ? Set evaluation as MAX INSC. . Recall points from cone. It would give you a sphere with tertiary position, variable diameter, and utilize MMC The 2d line method doesn't really do that does it ? Link to comment Share on other sites More sharing options...
[Ch...] Posted April 7, 2021 Share Posted April 7, 2021 Regarding MMC 'Bonus' of the feature : We've had this on ball pocket drawings as well. Engineer seems to agree its invalid.(not exactly a feature of size) Only way I could think of to add MMC is for the diameter of the cone intersection with the surface. Calculate smallest/largest countersink diameters, etc. based on a min/max linear from position tolerance. However, I would get Engineering's interpretation of this. Good luck. Link to comment Share on other sites More sharing options...
[An...] Posted April 8, 2021 Share Posted April 8, 2021 _ Link to comment Share on other sites More sharing options...
[An...] Posted April 9, 2021 Share Posted April 9, 2021 Please sign in to view this quote. See attached. Link to comment Share on other sites More sharing options...
[An...] Posted April 12, 2021 Share Posted April 12, 2021 _ Link to comment Share on other sites More sharing options...
[Aa...] Posted April 12, 2021 Share Posted April 12, 2021 Hmm...that's a good one. My understanding is that FCFs must be applied to features that are actually part of the workpiece. At least, I know that if position is applied at MMC, the MMC of that feature must be defined. Link to comment Share on other sites More sharing options...
