Star Probe Qualification
I am needing to set up a star probe and do not see anything in the cook book(s) on qualifying or initially setting these up. Is there any literature out there that helps describe the process?
What type of CMM and head (vast xt, xxt, RDS. etc) are you looking to create/qualify the star probe on?
Remember that if you select the F1 key with calypso open, it will bring up the help menu and generally if you do it with the feature or menu open you're looking for answers to, it will open to that section.
That said, I've attached a couple older work instruction on it and a couple hyperlinks to videos that should get you going in the right direction if nobody answers more specifically after knowing what you're working with.
https://www.youtube.com/watch?v=dDnHYVHQ6ys
https://www.youtube.com/watch?v=ocCJEC0iU6E
Stylus Qualification Methods (Part 2).pdfStylus Qualification Methods (Part 1) (1).pdf
